Mini LST: hacker brushless E30 + Quark Pro-car 22A
I am planning to hop my Mini-LST with Hacker brushless E30 + Quark Pro-car 22A. Has anybody done that? Any advice? Thanks. [8D]
CA
RE: Mini LST: hacker brushless E30 + Quark Pro-car 22A
Well, I was going to originally, but the Hacker has a low KV for such a big vehicle, it is a great motor for mini-t's and rc18t's though. The 22a is also a little low for the MLST, Id go 33a. Me being the pioneer of the Quark it is a great ESC.
Let say if I go for the combination (Hacker brushless E30 + Quark 33A ESC) with the original synthesized receiver and original servo (which come with the car), would there be a performance problem or even a compatible problem? Thanks.
CA
MI
Inverted, you do know kV has nothing to do with torque ratings, just the potential of the motors RPM per volt.
To truely know the ability of that motor for a larger vehicle you'd need to know kt, which is potential of the motors torque (oz/in) per volt.
The Vendetta is a heavier car, but at the same time, the Hypeion Y22L (3900, 4400, 5000) is one of the best for it. Not a Mamba 8000...why all in the missing "kt" ratings.
CA
Ok, I have to put in my 2 cents about Hyperion BL motors.
I am not a fan of them anymore. They are poorly made in my opinion. I've been through 3 motors so far, and all have literally fallen apart on me. I understand that hyperions run hotter so I always geared correctly, but to no avail. It was not that the motor would burn out, but that the motor can kept sliding off the motor assembly. Whether it was due to vibration or heat, I don't know. All I know is that in the two years that I have owned my mamba, it has never done this once. I also own Two Novak 1/10th systems, an Aon 4900, cool red 3500, GH 4700, Hacker E30, and the mamba. Out of all my BL motors the hyperion is the only motor I've ever had problems with. Now I do believe the Hyperion is a good company (I own their lipos and chargers), but in the category of BL motors, they fall short. Lastly, I have to send out my thanks to Troy at BPP for being nice enough to replace three hyperion motors at no charge. You're the man.
CA
I don't own a Hyperion motor. My mini-lst runs on what would seem a Hacker B20 with a built in heatsink in the can.
GA
Hello, I have a mini LST with a MAMBA Sport pack I'm currently using the pinion gear from the stock motor. I wondered if anyone had any comments or suggestions about gearing.Thks
MI
What batteries are you using? You may want to drop to a 20 tooth pinion if you are having a heat or cogging issue?
MI
Cogging would be jittering or stuttering on start up. With a 2 cell lipo, depening on the specific brand, you should be safe from cogging. Heat wise, it would be best to get a heat gun, but if it is getting uncomfortable to touch then it is probably too hot. Castle claims it's safe up to 200 degress, but I really wouldn't make a habit out of running that hot.
ORIGINAL: Jrgunn5150
i have a temp gun, the c4 got to 190 so i shut it down, i ordered a smaller pinion but it wont be here till thursday, *******s didnt have it in stock. i'll report on what happens with a smaller pinion but as i said before, im gonna go way down in the kv department.
I stumbled on this thread looking for info on the Hacker E30 motor.. apparently it isn't as good as the others out there? I currently own an AON 4900 and a Hyperion 6000 that i run in my mini inferno. The AON 4900 rocks for bottom end torque!! If i ever happen to go to a track i might toss it back in there =o) Right now i am running the hyperion 6000. It runs great too! it has a great top speed, and only loses a little torque to the AON. I am however on my SECOND hyperion. The first one unexplainably burned out during its test drive (i was using a 10t pinion so it was NOT overgeared) But Troy at B-P-P is great and hooked my up with a free one. So i guess if you get a good one then the Hyperion is a great choice. I haven't seen any of the Wraith 7K motors for sale anywhere.. must be good =o) With any brushless motor i've messed with i've always had to use a very small careful dab of thread lock to hold it on its mount... the power is just so much that it seems to be a necessity or else they will loosen up on you.
PA
I have a Mlst with a 6000 hyperion and a 8.4v ib1400 pack and Its Awesome. Its fast Has TONS of torque and I've had no problems with the motor at all. No heat isssues or anything. Its geared 60/23
I just ordered this motor for my 18t with the 33a quark. it is supossed to have alot of torque!
http://www.b-p-p.com/proddetail.php?prod=db_wraith
thats the combo i wanted. i ordered the hyperion though so i didn't have to wait for preorder. now i have a crapped out motor and i'm in the process of replacing. i think the hyperion is a great motor if you come across one that will last. i was extremly happy until it started going out.
hey he has had those motors in for about a week or so if you want to get one the time is now!
I have allmy stuff sitting here waiting to go into my rc18b. It should be a wheelie monster.
I sent 217 that was with a 2s lipo and charger.
