Will these work
CA
Will these work
will these all work in the minit and connect to geather what will i need
http://www2.towerhobbies.com/cgi-bin...&I=LXHAJ0&P=ML
http://www.jrradios.com/Products/Def...odID=JRP234275
http://www2.towerhobbies.com/cgi-bin...&I=LXTX42&P=ML
RE: Will these work
Yes those will work. For the servo tho I would instead go for the micro servo's that E-flight has. I bought that servo and went threw two of them. I don't know the same of it but its pretty much the same size but beefed up I guess you can say.
RE: Will these work
you would probably want a metal gear cause it would be stronger and with all that power if you lose control youre going to need a tough servo if you're going 50mph and hit a wall. it might still break though.
CA
RE: Will these work
couple of questions with the brusshless
1. (what is better a mamba 6800kv for 110) or a (Hyperion 6kv motor with a mamba 25 esc with a Kokam 3cell 1500mah lipo pack for 130) what is a better deal the mamba does not come with battery
2. what is faster a mamba 6800kv with a 7 cell from blind, or a Hyperion 6kv motor with a mamba 25 esc with a Kokam 3cell 1500mah lipo pack
3. how many mph will i get with mamba 6800kv with a 7 cell from blind
4. how many mph will i get with Hyperion 6kv motor with a mamba 25 esc with a Kokam 3cell 1500mah lipo pack
what woud u go with??/
thanks andrew
thanks andrew
MI
RE: Will these work
Keep in mind that you would need a Li-Po charger if you decide to go with them. I have a Dynamite Vision Peak Ultra and its a really nice charger for the price (89.99) it charges Ni-Cd, Ni-Mh, and Li-Po.
RE: Will these work
lipo pack in the mini-t i dont have one but bpp says this fits, [link=http://www.b-p-p.com/proddetail.php?prod=k_TP2000_2s&PHPSESSID=1213c69ca98b0ac14fe16a94c40b1da7]2cell[/link] and [link=http://www.b-p-p.com/proddetail.php?prod=L_TP2000_3s&PHPSESSID=1213c69ca98b0ac14fe16a94c40b1da7]3cell[/link]
CA
RE: Will these work
fould this charger http://www.rchover.com/inc/sdetail/36240 will this work
can any 1 answer my ?????? plz
RE: Will these work
hyperion is not as good of quality as the mamba the mamba would probably be better anyway.
well the hyperion would be faster cause you would be using a 3 cell lipo. if you had a lipo in the mamba then you would probably be going faster. the mamba would be a better deal even though there is no battery.
mamba 6800 and 7 cell blind 35-45mph probably closer to 40mph.
hyperion 6kv with mamba esc and kokam 3 cell 1500mah lipo 45-55mph probably closer to 50 mph.
i would definately go for the mamba just because i haven't heard much negative things about the mamba but i did here this one guy get a hyperion and he replaced it 3 times before he got one to work or he just gave up.
i'm pretty sure the balancer is just so you get a better charge and it doesn't overcharge.
CA
RE: Will these work
^^^^ charger
also what speed would i get with mamba 8000kv with the 7 cell
^^^^ charger
