1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Mamba/Quark Programing
Old 10-01-2006 | 05:06 PM
Dokioto's Avatar
Default Mamba/Quark Programing
I just want to know how do you program these two ESC. Do you use a computer,buttons on the ESC (I don't see any though)? Thanks for any info.
Old 10-01-2006 | 05:20 PM
Racing T's Avatar
Default RE: Mamba/Quark Programing
with the mamba you can use a computer if you buy the link ( $20 i think) or program it by listening to diferent souds and ligths and awsering the questions with your transmiter, full brake=no, full throttle= yes, it is very easy.
With the quark you have to program it by pushing a button in the side of the case and selecting different ligths with the trasmiter. ( can be very difficult sometimes)
In my opinion it is much much easier programing the mamba ( I have both) but the quark has more advanced progaming features. I personaly dont have the mamba USB link, but some people say that the mamba has more programing features if you use the link and that is waayyy easier than awsering questions. just my 2 cents.
Old 10-01-2006 | 05:24 PM
Dokioto's Avatar
Thanks, some were I heard you have to program the mamba by using a computer. I am very glad that it is not the only way.
Old 10-01-2006 | 05:25 PM
Seek and Destroy's Avatar
It's hard to get the quark into program mode. I want to try a mamba and see if I notice any differences.
Old 10-01-2006 | 05:27 PM
Racing T's Avatar
yeah I now[:@] today I was trying to put my quark in programing mode and it just went to advanced programing mode![:'(] I was so frustated... but then I realize that I have to reverse my throttle channel.
Old 10-01-2006 | 05:28 PM
I use advanced programming. I don't think there is much of a difference between the 2 modes.
Old 10-01-2006 | 05:34 PM
Racing T's Avatar
I really dont understand all the features on andvanced mode, like: what the heck is a out runner motor? like the first option in advanced mode
Old 10-01-2006 | 05:37 PM
Dokioto's Avatar
Sounds like the mamba is for me.
Old 10-01-2006 | 05:41 PM
ORIGINAL: Racing T
Outrunner is for planes. The airplanes use outrunners because of the torque they provide. The outside spins instead of the inside. If you have anymore questions about the settings, I can probably answer them.
Old 10-01-2006 | 05:55 PM
-Inverted-'s Avatar
Hmm.....I cant understand how one could possibly have trouble programming them, Ive owned both and they are both super easy.
Hard? All you do is hold the program button and turn the ESC on. As for basic and advanced modes, you have to setup BOTH. You cant just setup one mode and ignore the other. If thats what your doing I can see why your having problems.
Old 10-01-2006 | 05:58 PM
Well I only setup one. But thats probably because you setup both.
Old 10-01-2006 | 06:04 PM
-Inverted-'s Avatar
[:@].....I bet I know why your having problems. I had it set up for Li-Po cells with the low voltage cutoff enabled.
Old 10-01-2006 | 06:21 PM
Racing T's Avatar
ok, and what about the Ni-mh low-high and li-po low-high, I am now using 6-cell ni-mh, so I set up in high or low?
Old 10-01-2006 | 06:30 PM
-Inverted-'s Avatar
What brand of cells are you using?
Old 10-01-2006 | 06:56 PM
ORIGINAL: -Inverted-
I reset the advanced programing, not the basic. So if the basic is set for lipos, I better change it.
Old 10-01-2006 | 06:58 PM
Racing T's Avatar
SMC cells 1200mah
Old 10-01-2006 | 07:03 PM
-Inverted-'s Avatar
ORIGINAL: Racing T
SMC cells 1200mah
Put it on Ni-Mh low.
Old 10-01-2006 | 08:07 PM
Racing T's Avatar
ok thanks, in what case do I want to put it in high?
Old 10-01-2006 | 09:31 PM
-Inverted-'s Avatar
When your using more cells.
