missing anything?
FL
missing anything?
Ok so im gona get myself a mini and ive decided on a rc18t i looked through everything and this is what i came up with now i need some supervision from you mini-guros, am i missing anything, is this setup going to work, am i paying way to much, could i get the better stuff for about the same price, and last but not least am i just stupid for doing this.Be honest with me i really dont care if you slap some sence into me. Im going for speed not really gona be track star, i might do some drag races with freinds but thats the most competetion il get. How much do you think the run time will be?
Here is my setup:
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKAP3&P=RF]The truck[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXASX273&P=7]The radio/reciever[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJFY5&P=ML=&I]engine/esc(updated)[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXN679&P=7=ML]servo(updated)[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKX39&P=M]deans plug(ive heard there great)[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMAG8&P=7=ML]Battery(updated)[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMAH9&P=7=V]charger(updated)[/link]
Here is my setup:
CA
RE: missing anything?
ORIGINAL: Frank88888888
Here is my setup:
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHAH9&P=&I]engine/esc[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXTX42&P=ML]servo[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJA83&P=ML]Battery(i have two of these at home laying around and a charger)[/link]
Here is my setup:
You are also going ot want to take a look at MIP superdiffs, CVD's, and a RPM front bumper.
The others have already mentioned that your batteries are too big and will not fit. Take a look at some Intellect 1400mah batteries.
get that battery if you are going for speed http://www2.towerhobbies.com/cgi-bin...?&I=LXMAG8&P=7
FL
Ok so batterys i knew i was going to need different ones, i was thinking about the li po but i hear you need a good charger or they will explode[:@] which charger yal suggest for lipo? ok and il change the motor to the competetion or x.As for the bumber and dif those i can wait til those parts actually brake to get new better versions of them.
CA
There are a large variety of chargers, if you get batteries in 500 mAh increments one without a digital amp adjuster will work (which means cheaper for you).
FL
Ok so i couldnt find any bats with 500mah i imagine that 300mah will be close to it am i right if i am will [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNKU9&P=7]these[/link] work and if they do is [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHNW5&P=ML]this[/link] a good charger and about that charger do i need this [link=http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXL356&P=V]power source[/link] for it to work?
My Feedback: (31)
WV
for my 2c on the charger here ya go.. an EXTREMELY versatile charger that 20-25 of my flying club uses with great success
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=MPU92531]http://www.horizonhobby.com/Products/Default.aspx?ProdID=MPU92531[/link]
its capable of 1-5 lipo/lion "i may be wrong on that cell count but im pretty sure thats it"
1-14nimh nicd
lead acid
and all from a 13.8 volt power source
and for 75$ you really cant beat it
1-14nimh nicd
lead acid
FL
Damn but tower doesnt sell it i rather buy all the stuff together from tower than buy it from two different places plus i have some nice discounts on tower.Im begining to think im gona need one of those expensive chargersHow much of a difference will there be if i dont get lipos and will it be cheaper?
BTW: i was wondering does the kit or the motor bring a pinion? i know it sounds stupid but i was just wondering
CA
No, go with a higher mAh battery, what I mean is if you get one thats 1500 or 2000 mAh it will be easier to get a cheaper charger then getting say 1350 mAh.
FL
Ok so for these [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMAG8&P=7=ML]bats[/link] which charger do yal suggest.
CA
Well, what I mean is cheap chargers dont have digital amp increments, they go from 500 to 1000. So, if you get a battery with 1000 mah you can use a cheap charger. I highly reccomend a charger with digital adjustment if you can afford one though, it will allow you to charge higher mah battery packs in the same amount of time as lower mah batteries with cheaper chargers.
FL
Ok i changed the servo but about the charger im still not shur im gona do some research on tower and see what i come up with and how much $$ it costs cause the amount i was gonna waste at the begining was only 300 and the price seems to be going higher and higher as it usually does in this hobby.
FL
Ok is [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHNW5&P=7=7]this one[/link] any good? seems to cheap to be any good
FL
Ok ive decided to go with what doah said so i picked [link=http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXEYD4&P=V]this charger[/link]
FL
Lol srry but i changed it yet again to [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMAH9&P=3]this one[/link] and i still want to know if i need a pinion
srry i didnt read that last post ty! for telling me i didnt need one
