lipo charger
lipo charger
Im getting this charger http://www2.towerhobbies.com/cgi-bin...&I=LXHNW5&P=ML and this battery http://www2.towerhobbies.com/cgi-bin...&I=LXMAG8&P=ML what plugs should I use to connect the battery to the charger? because I see their not the same. and does it plug into the wall because Im new with electric and I see some lipo chargers dont so I dont no what power source they get
CA
RE: lipo charger
I would reccomend installing Deans Ultra plugs on the battery and charger. The linked charger is DC, which means you will need a power supply of some sort.
My Feedback: (325)
RE: lipo charger
Here's a whole lot of connectors , the red two pin connector fits the charger, but the battery comes without a connector so it will depend o what connector you are planning to use.
http://www.electrifly.com/miscproducts/adapters.html
