Just picked up an Associated 18T today....
CA
Been into RC stuff for decades... get into it hardcore for a few years, get PO'd at myself for sinking tons of money into it, eventually sell some of it off.. wait a few years and repeat the cycle ... So today, the 18T really caught my attention... and I picked one up at a local HobbyTown USA. Battery's charging right now, .. I'll take it out for a spin tomorrow, but am looking forward to it.
So, is it true that the 18T and 18B are exactly the same except for the tires and body?
Where's a good place to buy battery packs and motor upgrades?
WI
RE: Just picked up an Associated 18T today....
i have the rc18mt. yep, you are right, the only difference between the three is the rear shock tower (B has the wing mount holes, but you can still mount a wing on the MT and T rear towers), tires, and the mt is geared a tooth lower. check out unitedrc.com or cheapbatterypacks.com for some good battery packs. motor upgrades.... try towerhobbies, or amainhobbies.com. the mamba brushless is nice. i just ordered the 18B wing mount and vendetta wing to make a "truggy" out of mine, already have some nice red aluminum wheels with pin tires on it right now. also have a jconcepts illuzion body for it, but im waiting for the wing and mount to get here, then i'll paint that and mount it up.
NV
Hey Cal, I know how you feel. I've done that before in the past myself. About the 18T, you should love it. But there are a few things that you should do to it before running it, to make it more reliable from the start. I hope I don't get in trouble for sending this link, but I know how hard it is when you get a new RC car or truck and have to search through every nook and cranny to find any needed mod info. If this link is not allowed, please forgive me.
http://www.one18th.com/forums/showthread.php?t=14422
Definately get some shims for the diff if it didn't already have three on the same side.
Also the differences are
18b has a different top plate, different front and rear shock towers, wing mount with a wing, different wheels and tires, and a body.
The 18mt and 18t are pretty much the same except for the wheels and tires, body, and the 18mt is geared 10/60 and the 18b and 18t are geared 14/55. And the 18t and b also have a different spur cover. Thats the little cover on the bottom of the chassis held on with 3 screws. change that to a 60 so you can use and spur gear up to a 60 tooth.
CA
Where can I find some kind of cover for the spur/pinion gears? it's wide open for pebbles/dirt to get into.
I took it out today for the first time... played around on my concrete patio (drove the dog crazy!), and on my lunch break, took it to a baseball diamond (where I heard stuff get caught in the gears ) ...
I also ordered 2 7-cell packs from cheapbatterypacks.com today
When I went to the hobby store where I bought it, they had no idea about any kind of cover for the gears....
Help!
Help!
CA
CA
Wow.. 25 bucks!!!?? I was expecting maybe 5-8 bucks .. I was just looking for a formed piece of lexan or something.. not a $25 peice of CNC cut aerospace plastic! is that the only option??
CA
no other options for a gear cover??? Heck, at that price, it's worth just gambling and hoping I don't grind up my gears with dirt/pebbles.. and if they do, I'll have to replace them several times before it would have been worthwhile to get the NASA - legal gear cover
CA
haha, A bit spendy but when your the only company producing the items you can control the prices to your advantage.
MD
Or you can make one yourself. I did that with left over lexan from body shell.
http://www.one18th.com/forums/attach...achmentid=6870
Other DIY options:
Other DIY options:
VA
ORIGINAL: golfcarterforlife
or you can just get alum gears.
Really, I am not being sarcastic if there is a link to some aluminum gears, I will buy them because I hate plastic gears.
You don't need metal gears, plastic will hold up fine.
http://www.thetoyz.com/cart/thetoyz_...cat_name=RC18T
VA
ORIGINAL: rc18t145
I haven't replaced a single gear in my tranny since I shimmed my diffs. All you need is $2 for shims. Which is 2 packs. You put 3 on each diff. On the opposite side of the teeth. I haven't even screwed one up with the brushless.
Banned
VT
http://thetoyz.com/cart/thetoyz_deta...cat_name=RC18T
if you look on there you can find tons of them blue,red,sliver and titium
CA
Wow... this thing is fun and durable! I've smacked a couple curbs pretty hard with it, and no breakage (yet).. however, the stock tires leave a lot to be desired. I'd love to get some Dirt Hawg tires (mounted on rims).. anyone know where I can buy some?
ORIGINAL: cal_gecko
rims - http://www2.towerhobbies.com/cgi-bin...?&I=LXLPX3&P=M
