Glow Start Question
RI
Glow Start Question
Well for Christmas I got a SportWerks Chaos, and a Gallon of 30% fuel. So can all glow starts work or no? Also what glow stat do you recomend?
Matt
Matt
RE: Glow Start Question
I don't know that all will work. But this is the one I use. http://www2.towerhobbies.com/cgi-bin...&I=LXJGS6&P=ML It tests the glow plug to see if it's good or bad. It's one of the more expensive ones, but I liked it, and it was made by dubro. I haven't used mine yet, cause I just got it along with an os 18tm, so I will use it soon.
Edit: what I mean by "not all will work", is I am not sure if it uses smaller plugs or not. it probably uses normal size plugs though.
CA
hey rc18 what car are you using it on???and do you think that that glow starter will work for 1/109 scale trucks like a t maxx?????????????
This is the one I am going to use for my next, http://www2.towerhobbies.com/cgi-bin...?&I=LXUM80&P=7
RI
I got this one http://www2.towerhobbies.com/cgi-bin...?&I=LXGEB8&P=7 Its great.
ORIGINAL: maxxin2.5
RI
ORIGINAL: rc18t145
THats exactly what I am using it on, my t-maxx. A glow starter should work on almost any truck/car, except for the minis cause they might use smaller plugs. I bet they are the same size though.
ORIGINAL: maxxin2.5
