Highest capacity Lipo for Mini Quake
NV
Can anyone post a link to where I can get a high capacity 2S Lipo battery for the mini quake? I found a 1200mah lipo that fits, but I cant find a larger capacity one than that that will fit in the stock compartment. Thanks for the help.
NV
RE: Highest capacity Lipo for Mini Quake
Sweet that is what I have been looking for. Thanks a bunch. I checked dimensions and it fits. Price is good too.
My Feedback: (325)
It should be good for 20 amps or less and will run a stocker about 20 minutes at nearly WOT. If yours is brushless and real fast then the current capability needs to be checked.
NV
I'm running the VR3 motor on a mini quake. It should be ok for that. I am however building a brushless mini quake with the air power 4700 motor but thats going to get an 11.1V lipo battery.
My Feedback: (325)
It should be just fine. For the 3S this is the highest that I found would fit.
http://www.vampowerpro.com/batteries/pop1700mah.htm
NV
I did some searches and the 2100mah batteries I found are really long. I think around 90mm is max length without doing some modifications. The ones I found were over 100mm.
