Which drive shaft to use in a Scion Evo?
RE: Which drive shaft to use in a Scion Evo?
Is it a mini-z or xmod? If it's an xmod, my 4wd kit came with 3 different size shafts depending on which truck I had. Mine was the xmod evo truck.
WA
It's an xmod, but the instructions don't say which shaft the Scion uses... I think the Scion came out after the awd instructions were created
Well I would guess the long one. most are the long one. But it's most likely the short or the long. I haven't ever used the medium on my gen 1 or 2. But you can tell wether or not it will work because you should be able to do it well it's apart.
good luck!
good luck!
