MLST Outdrives
MA
MLST Outdrives
Does anyone make aftermarket outdrives for the Mini LST? Also i havent gotten a response on my other question. What is the problem with the Quark 33A Pro Car and the factory MLST reviever?
CA
RE: MLST Outdrives
ORIGINAL: hpibasher2
What is the problem with the Quark 33A Pro Car and the factory MLST receiver?
RE: MLST Outdrives
yes they are, go to www.thetoyz.com they have alum and titanium ones, and I anwser your question on your other thread but anyways here it is;
the problem is the throttle curve, let me explain, all the esc need to know your radio, for example, they need to know when your transmitter is at full throttle, neutral and full brake, to give the respective order to the motor. Thats what we do when we set up a esc for the first time or for a different radio. now the problem with the stock radio and quark is that the stock radio has a very bad throttle curve so the quark can be set up right, the problem is the quark doesn't recognize when is at full throttle so it goes very slow.. hope you can understand what I am saying I know I said it very confusing.
MA
RE: MLST Outdrives
HangGlide, that is exactly what i want to do... but this whole wriath thing is bugging me... and also RacingT thank you, but i found all titanium outdrive BUT the ones coming out of the diff, i would like to find steel or titanium.
MA
RE: MLST Outdrives
im looking for titanium or steel to the front or rear wheels on the inside, the outdrives themselves that attach to my MIP CVD's
