RC18B -----> RC18T
TX
RE: RC18B -----> RC18T
Download the manual for the 18T and compare it to the 18B manual. I think there is also some minor small parts as well. I wanted to do the same thing .... If you want it exactly the same as the 18T ... you might as well buy the 18T. If you just want the look you could get away with the parts everyone else mentioned. After seeing what it would take, I came to the conclusion that I would be better of buying a 18T instead of converting but others may not agree. Thats why I said D/L the manual for the 18T and compare them and decide whats best for you.
ORIGINAL: squeaky penguin
I want to make my rc18b a 18t. Is the olny difference the shock towers and body?
http://aedownloads.com/pdf/convert_mini.pdf
Lists everything you need to go from one to the other...
