Vendetta Gallery
SC
RE: Vendetta Gallery
No these are HPI rims for 1/10 scale cars, and the tires are Pro-line. I use these on the street.
The aluminum arms came from RCMart.com, look under hop up parts for the Anderson MB-4. They are strong, but very heavy. I don't plan on bending any of these any time soon!
SC
Dude, nice set!!! And no, you don't need an adapter. Any 1/10 scale touring car wheel (or rally) that's 26mm and has the hex will fit perfectly.
Good purchases!!!
Happy New Year!
Darin
Good purchases!!!
Happy New Year!
Darin
SC
See my above reply: RCMart.com. Yes, they have the upper camber arm in blue or silver aluminum too. Warning- these are very heavy!! But I'm going Lipo, so that should shave off some serious weight.
Yes, on 8 cells, it tops out at about 48 mph with the Air Power and 19T/45T gearing. With my Mamba Comp. X, I don't even want to go there.
Thanks!
Darin
Thanks!
Darin
ORIGINAL: Bayou_flyer
darindotson where did you get the auminum front arms and are there some top arms in aluminum
CA
tho alum arms are worthless.. only bling factor.. i have taken mine off and will never use them again unless that company makes replacement bushing
CA
ORIGINAL: junebug48
[8D]hi guy,s . im going to take it apart today ang grease it all up and oil the motor so it will be rtr . thank,s darindotson and Racing T .
