Cant Figure Out
MA
Cant Figure Out
Does anyone know how to program the XPS Speed Controller, its the stock one in the RC18 family. Someone gave me one and im putting it in my mini t
AZ
RE: Cant Figure Out
Um you should have gotten a little plastic stick that came with the car to program. You get the stick, put it in the hole and press the button inside.
MA
RE: Cant Figure Out
ORIGINAL: clockwork1
hpibasher2 - I'll need to check my manual when I get home in the morning, but if I remember correctly, you press and release the set button with your finger OFF the trigger, then press and release while pulling the trigger (full throttle), next press and release while pushing forward (full brake/reverse).
I'm sure someone will confirm or correct by the time I look into it. Good luck...
MI
RE: Cant Figure Out
You press and hold the ESC button for about 3 seconds. With the throttle trigger in the neutral position you press it again. Then you pull the trigger to full throttle and hold it while pressing the button again, and do the same for reverse.
MA
RE: Cant Figure Out
right on fastmax. That's it.
Also, make sure the radio and esc are both on and the throttle trim is set at neutral and if you make a mistake it says to disconnect the battery for about 10 seconds. I don't know why you couldn't just re-program it, but that's what the manual says.
In addition to what fastmax said, there are lights to pay attention to. When you initially hold the set button for 3+ seconds, the LED will flash red/green to confirm setup mode. Then after you press to set neutral it will turn green. Then after you pull the trigger and press it to set full throttle it will turn red. Finally, after you push the trigger and press it to set full brake the LED flashes red/green 3 times simultaneously.
