Mini T
RI
Mini T
Ok so I took my stock Mini-T..
I installed..
Stock MLST Radio, and ESC
Stock MLST Frenzy 370 Motor
JR241 without saver
23T Pinion, 60T Spur
9.6V 8Cell Elite 1500MAH Packs
This truck is so fast, I cannot believe it.
Can I make the stock LST shocks work on this truck?
I installed..
JR241 without saver
RE: Mini T
Wow, 8 cell. A 23t pinion. Does it overheat?
Did you need a different motor plate to mount the 370 motor. I might do the same with mine.
I think LST shocks would be a little large.
Can I make the stock Mini-LST shocks work on this truck?
RI
RE: Mini T
I used a dremel hardcore on the stock plate, to make it fit. LOL
Also, I dont care if it overheats, it is super fast. But the motor doesent get too hot to the point I cant touch it.
I got 2 of the shocks on, fronts will not work at all, but the backs did with a little modifications..
Here is what I did..
Here is the tie rod, I flipped it and extended it a bit..
RI
RE: Mini T
I have The Original one, with the old gray case and all.. Cant kill this thing, and I have used it to do things it shouldnt have done... lol
