rc18mt troubling
FL
rc18mt troubling
hey
i just chaged the stock motor in my 18mt for a reedy mini mod 19t motor.
after about 5 minuts of run time the motors temperature is 200f and the esc is 135f.
is this normal? if not what should i do to prevent it.i thought about putting in a heat sink.
is this a good idea?thanks
RE: rc18mt troubling
I'm gonna hitchike on your thread with my own 18mt troubles.
I ran it threw the snow today [:@] and now when i turn it on the motor goes full speed. What did I break? It smells burny... []
ORIGINAL: rcnitrodriver
hey
hey
ORIGINAL: Big Green Machine
ORIGINAL: rc18t145
Protect the electronics next time. I would try throttle trim first, but I bet you screwed up you receiver, esc, and servo. Easily 100 for newer better parts.
The servo seems to be working fine and I unplugged the reciever and the motor but the ESC still displays the red and the green leds. GThen I just plugged the motor back in and fired it on to try the throttle trim but the ESC started smoking big time. I guess thats the probelm then?
The stock esc is pretty crappy anyway. Mine went up in smoke because I landed a big jump.[&:] I think it's because I also drove it in the snow, unprotected and with no body on.[&:]
ORIGINAL: rc18t145
I just read in the thread above this one that the 19T motor is not recommended for the MT on AE official site:
http://www.rcuniverse.com/forum/fb.asp?m=5267718
They say the tires are too big and recommend the 19 stump puller motor that has more torque.
That may be the problem with the excessive heat.
