FOR PPL WITH MAMBA IN MINI T
RI
RE: FOR PPL WITH MAMBA IN MINI T
I think I had this http://www2.towerhobbies.com/cgi-bin...?&I=LXCBC7&P=V Its not out anymore but I still have it.
Well my favorite mini t set up is like this. A mamba 8000 with 25 esc, 9/60 gearing, 2s lipo 1900mah, hitec hs-65MG servo, hitec hs-03MM rx, poly amide bearings, losi oil shocks w/40 wt rear and 35/wt front and the rest in susp is secret (as far as pistons and springs go it's up to you and your track conditions), DD slipper, MIP diff and cvd's, K factory alum chassis and arms, knuckles, hubs. A good set of step pins on rpm rims, lindsford turnbuckles.....hmmmmmm...thats it I think.
