Mini T Hs-55 Question
MA
RE: Mini T Hs-55 Question
how would the stock mounts fit, they have 2 holes and the hs55 has 1 in the center?, i dremeled out the stock servo saver to fit but i want somthing less rigged
MA
Thank you Racing T, I found that just before your post, now the problem is keeping it stationary. I tightened the servo brace all the way down and now it just jiggles a little, mabye some servo tape under it or somthing.
