Broken Servo?
AZ
Broken Servo?
I have a mini T, but the shafts that pull the front wheels have been bent a few times (and bent back into place), when it has come down from a jump over a curb. The servo would just stop responding at that point.
Before I just opened up, removed the servo motor (used to control the front wheels), and it would start working again, but now, with the servo out, moving it back and forth it seems to just stop sometimes. Could it somehow be broken, or is there something else going on?
RE: Broken Servo?
Sounds like you need a new one. If you are going to keep this lil truck I would recommend getting yourself a new radio system all together. If you were to go that route it would need a new esc, servo, reciever. You can also just replace the stock servo for a few bucks but I can assure you it will happen again. Almost not worth buying a new stock servo unless the budget says no to a new radio system. With a good radio system you can use it in all kinds of other cars/trucks/boats too.
