A good fast charger for my Losi Baja...
AZ
Is it possible to find a fast charger (20-30 min) that will charge the smaller 7.2 Losi packs safely? I have the 2 hr charger, but I would like something a little faster...Is there such a thing?
Custom
Custom
RE: A good fast charger for my Losi Baja...
I dont think it would be safe. To charge the team losi 1100mah in 30 mins you would have to charge it at 2.2amps so you are risking the pack for permanent damage.
NJ
you can charge at more then 2.2 amp and not damage it. I do it all the time and have never damaged a pack in 25 years.. Just monitor th etemp to be sure its not overheating
Frank
Frank
yeah sure you can charge at 2.2 as long as the charger can, but depends on the battery, Im sure you cant charge a micro t 150mah battery at 2.2amps.
