Mini-t stripping gears like CRAZY!!!
PA
hello,
I have a mamba powered mini-t and just yesterday i stripped out 3 of those little plastic gears that are between the diff and metal gear that the slipper is attached to. Can anyone help me out with why i am stripping it like crazy. this has never happened before.
Thank you!!
Thank you!!
RE: Mini-t stripping gears like CRAZY!!!
I just stripped mine out with a 3s 5400kV combo. It was suggested to me to get an aluminum gear box to cut down on flex and heat. I have yet to do any testing to see if it worked, waiting for the threadlock to cure on the pinion. [link]http://thetoyz.com/cart/thetoyz_details.lasso?id=6396&cat_name=[/link]
PA
no i dont have pics. it may just be my gear housing like you said. The housing is about 3-4 years old so its farting dust. i also noticed my whole dual disk slipper clutch has a lot of play in it.
PA
the ,esh is fine. its the gear inside and it still meshes fine. i drive it for about5-10 minuets and then it all of a sudden stripes, i think im gonna just get another gear case and see if that helps
thanks for all your help!!
