Mixing Brands???
Mixing Brands???
Hey all, i was looking at getting a mini baja and going BL. This will be the first time i will be actually using a BL motor. keep in mind though i know plenty about them.
At my LHS they sell the Dynamite C4 and the Mini Tazer. I like the motor but not the way the esc has no programable options, im mostly concerend about li-po cut-off and throttle settings.
So is it possible to say buy a C4 motor and then a mamba (or if there is any other programable esc's PLEASE mention them)
Thanks in advance.
Btw is the telkin a good esc to be using with either the 8000kv or the 9200 kv Dynamite C4 motors. http://www.thetoyz.com/cart/thetoyz_...LESS%20SYSTEMS
http://www.modelflight.com.au/horizo..._brushless.htm
Thanks in advance.
MD
RE: Mixing Brands???
yes you can buy just the motor from here http://www.horizonhobby.com/Products...ProdID=DYN3715
and yes the Tekin ESC is ok to use with the C4 motor
I was just looking at the info on the telkin and what does it mean by "except for the 8000kv" down th bottom of the page.
http://www.thetoyz.com/cart/thetoyz_...ESS%20SYSTEMS#
