What pinion gear to use w/ Orion Baja micro?
CA
This would be for the Tamtech Porsche 934 1/12. I believe the car comes with 14, 16, and 18T gears to go along with the stock 370 can motor. If I upgrade to the Orion Baja, should I try something lower like 12T? thanks
CA
RE: What pinion gear to use w/ Orion Baja micro?
When it comes to gearing a motor, how do dirt and on-road compare? That is, just because 17T works great on dirt, does that mean it'll be ideal on road?
