Mini baja!!!!!!!!!! :) please read!!!need help!!!the truck wont turn!
TX
i just bought a new baja mini by team losi it is a great truck except for the easy flipping.i flipped it at full throttle and now it wont turn.Can someone tell me what it wrong with it????The wheels are stuck and turned right!when i flipped it did like 3 flips and came down on the side any info please tell i will appreciate it greatly if some one helps[8D]
TX
RE: Mini baja!!!!!!!!!! :) please read!!!need help!!!the truck wont turn!
well the back tires turn but the front are jammed theres a small spring with some ball joints attached right behind the suspension arms.
CA
ORIGINAL: warhead evo4164
TX
well on the front the tires wont turn they are locked
spin=forward and back
turn=left and right
turn=left and right
CA
ORIGINAL: danen
man give him a break
TX
well i just checked the servo and it is damaged.so thank you all for the help
OH
If it's the stock one, now is a good time to upgrade to a hitec or something else. Stock servos, or RTR electronics for that matter, are usually the cheapest they can put in it. If you have the money get yourself a HiTec servo.
TX
new problem!!!!!!!omg i just bought new steering servo now the truck wont even turn on i have no idea what is wrong with the car!any1 know?????
NV
HHHHMMMMMMM.... I am trying to think back to mine. Did you put a new or different battery in it?
TX
well i sent the truck back to horizon hobbies they said they might replace the servo if its under warranty yay
TX
on the battery thing i have 2 batteries that i use both charged up the same time and both 7.2 when one runs out i switch to the other one i dont know if i should let the motor cool before switching quickly and just putting the other one in and running it when the motor was hot which is what i did
