Ima Bad boy 9V Powa
TX
Ima Bad boy 9V Powa
Well, i think i got something way better than brushless lol. I took a 9v energizer battery and plopped it in my little buddy and took off. I cant give it full throttle anymore cuz itll just spin tires for as long as i hold it in. Its deffinatly faster than stock, WAY FASTER. i only did this because i have an extra motor so if i blew mine i didnt care. The suprizing thing is tho the esc/rx didnt get hot at all and i ran it for a good 5 mins strong. I dont know how long itll last yet but this may be a very good alternative battery source.
TX
RE: Ima Bad boy
Heres a lil clip just b4 the batteries in my camera died.
http://www.youtube.com/watch?v=rztyj2WVjbo
TX
RE: Ima Bad boy
haha yea, i kinda clunked into it a lil hard. But its fine now, i just put the cameras battery on the charger for a quick test and it still works,. But now i gotta wait 4 hours for it to get completely charged.
TX
RE: Ima Bad boy
A couple more pics i took rite after i got the camera working. Now i know this will work i went ahead an soldered the 9v adapter straight to the board to now i can use bot the 9v and the stock battery packs. Theres not much you cant do with thing litte buggers
TX
RE: Ima Bad boy 9V Powa
ORIGINAL: maxxdout
Did you make that chassis yuor self? It looks sorta like the thing i did to my mini-t....
ORIGINAL: Takedown
Its cool and all but its definetly not good for your esc.
TX
ORIGINAL: maxxdout
Isnt lexan a little flimsy? Well i guess not cuz were talkin bout cars that weigh 1 ounce!!
ORIGINAL: andrewtexas123
Great Idea and keep up the good work!
PA
LOL, I used aluminum for my mini-t when i did that, i owuld do this to my micro-t, but i wouldn't be able to find a body and i already have 1 few bodies i wont be able to use
TX
Im not to sure yet which one fried my motor but it just went. The way i have it set up now i can run BOTH the 9V and the stock batt at the same time, so thats 13.8V's. I ran that for a couple mins and then the motor went south real fast. So im not sure yet if the 9v hurt the motor then the extra 4.8v's blew or what but im not doing that gain lol . At least not until i get the FET's in so i can stack em so itll handle the power. These are the only pics i have of just the bare chassis. Hopefully it helps.
TX
ORIGINAL: bullfrogfrog
if u wanted to run 9v power all the time what esc would u use?
Search google for "B-P Hobbis" Look under the micro planes and then motors. They have a couple of 180 size motors let me know what you find!
Andrew
Andrew
TX
I was just going to go to my lhs and get an extra stock motor mount and just bore it out for the 180 motor. its to late to call hobbytown now but i will run over there sometime tomorrow and see if they have any 180's in stock. If they do they ill get one and a spare motor mount.
TX
ORIGINAL: Mz
i think your truck is slightly out of alignment.
