Xray M18T M18MT Nt18T NT18MT Foams
WA
XRAY Micro Truck Foam Tires Mounted click to enlarge
(click to enlarge)
Premium-quality, high-density foam tires mounted on strong, rigid 28mm-wide white dish rims. The foam tire is solidly bonded to the wheels and pre-trued to an optimal starting diameter. May be trued using HUDY Tire Truer with special wheel adapter. Fits M18T or NT18T. Set of 2 mounted tires.
Tires are packaged in a sealed air-tight vinyl bag to keep the tires fresh as long as possible. Packaged as 1 pair (2 pieces). Tires are available in 4 popular hardnesses to give you abundant choice for any racing conditions around the world.
Part Numbers:
389561 M18T Rear Foam Tire Mounted (25Deg) - White (2)
= (25deg - white compound)
389562 M18T Rear Foam Tire Mounted (37Deg)
= (37deg - magenta compound)
389263 M18T R/F Foam Tire Mounted (42Deg) - Purple (2)
= (42deg - purple compound)
389264 M18T Front Foam Tire Mounted (42/47Deg) - Purple/Orange (2)
= (42/47deg - purple/orange dual compound)
(click to enlarge)
Part Numbers:
XRAY Micro Monster Truck Foam Tires Mounted click to enlarge
(click to enlarge)
Premium-quality, high-density foam tires mounted on strong 34mm-wide XRAY Starburst wheels (made purposefully softer for extra grip). The foam tire is solidly bonded to the wheels and pre-trued to an optimal starting diameter. May be trued using HUDY Tire Truer with special wheel adapter. Fits M18MT or NT18MT. Set of 2 mounted tires.
Part Numbers:
389581 M18MT Rear Foam Tire Mounted (25Deg) - White (2)
389582 M18MT Rear Foam Tire Mounted (37Deg) - Magenta (2)
389583 M18MT R/F Foam Tire Mounted (42Deg) - Purple (2)
= (42eg - white compound)
389584 M18MT Front Foam Tire Mounted (42/47Deg) - Purple/Orange (2)
(click to enlarge)
Part Numbers:
