vendetta brushless q
i have a vendetta st and i want to go brushless. i know that the output shaft is an odd size and you have to use the right pinion gear,what my question is, is what pinion do i need to buy to run the trinity cobalt brushless motor( the same size output shaft as the mamba,tieken,blah blah most other mini motors). i heard the robinson racing metric pinion will work,but i want to know for sure and exactly witch one thanks.
RE: vendetta brushless q
It might be worth reading Jaejw1's reviews of brushless motors before you make a decision (permax and ammo motors are really popular). I believe the stock detta pinions are 2.3mm and the robinson racing metric pinions are 3.2mm. Do you know the shaft size of the trinity? I thought the mamba stuff was 2mm but I'm not sure.
The trinity cobalts have a 2mm shaft. You can use atomic 2mm metric pinions. You can get them at thetoyz.com. Search "atomic pinion" in the vendetta section of the store.
