Whats the fastest rebuildable brushed motor?
NY
Well I was wondering what the fastest brushed motor is. I have a Vendetta ST and I was looking to make it go a little faster. I will be getting a brushless setup closer to December. But for now Im looking for a motor that is fast and I can change the brushess,springs etc... Any ideas?
CA
RE: Whats the fastest rebuildable brushed motor?
Funny you have one of the fastest motors already! Just time your VR-3 and its almost as fast as a brushless.
Oh but its not rebuildable
NY
Yea Im looking for a rebuildable one. I have to say tho the motor in my Vendetta ST if freakin FAST. I just wish I could change the brushes [] So what "Rebuildable motor" is as fast or faster then that?
Wow, so the VR3 realy are fast! would they work well in a MLST2??
EDIT: Do they fit, and where can i get them from cheap?
Checkout the Graupner Speed 480bb Race 7.2 ? i have used it in my MQ erlier and it was nice,, little bigger than stock motors..but that is just mm´s
WA
The VR3 is not rebuildable!
-You cannot replace the brushes
-You cannot (well easily) retrue the comm.
*Edit the Graupner Race 400 though you can replace the brushes at least. The non race version is closed endbell
we have already pointed out that it is not rebuildable. why do you say that like they said it was rebuildable and you are a master tech that works for duratrax and has to prove his point.
WA
ORIGINAL: indianadigger
Anyhow, neither of those will work. They have a smaller diameter shaft.
You need a 2.3mm or 3.17mm shaft on the motor. The only rebuildable 380/400 size motors I know of are the LRP shark motors in Europe. You will have to import them if you want one. other than that, you are stuck with your run of the mill grauper 400 motors or a Rad 400 (which I can't find anymore... [])
