micro t antenna
SC
RE: micro t antenna
Under the circuit board, right in the middle at the back. But don't bother with this! If you're glitching, just screw a stiff wire around that little gold screw on the back right side of the circuit board, and then clip off the old antenna. You will get excellent range, and no more glitching. Good luck!
