slider chassis on a mini-t?
I was wondering if the Mini-Slider's Chassis would fit the mini-t the rear holes look like its a match but im not sure about the front... This would be a good and cheap way to extend your mini-t chassis.. Thanks in advance
RE: slider chassis on a mini-t?
http://www.losipartshouse.com/servle...-Slider/Detail
http://www.losipartshouse.com/servle...nd-Rear/Detail
http://www.losipartshouse.com/servle...rap%2CR/Detail
You need these parts to convert it. Then you need to get extended body mounts and/or the bumper with body posts depending on the body you want to use.
I think mini-slider sounds stupid. I call mine a mini-t with oval conversion, or with mini-s chassis, or something like that. I'm going to start racing dirt oval with mine next season.
