1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
OFFICAL MINI-QUAKE THREAD
Old 11-13-2007, 10:53 PM
barefootdan
Default OFFICAL MINI-QUAKE THREAD
where is it!!
if not here is one lol
might get a mini quake; good right?
Old 11-13-2007, 11:06 PM
barefootdan
Default RE: OFFICAL MINI-QUAKE THREAD
the mini quake is deans connector right?
anyways i need an adapter for it to become like i think it is 7.4 voly one?
the ones used on the rustler cuz i have a speed charger and want to use that for the battery pack.
anyne know where to get one?
Old 11-13-2007, 11:12 PM
Mz
Mz's Avatar
theres already a mini quake thread.....
Old 11-13-2007, 11:13 PM
barefootdan
oops well can someone answer me question????
Old 11-13-2007, 11:23 PM
Mz
Mz's Avatar
yeah, the mini quake can be converted to deans. the REGULAR mini quake comes with tamiya mini connectors which are crap.
Old 11-13-2007, 11:26 PM
barefootdan
so should i convert then get an adapter?
to a normal sized tamya
Old 11-13-2007, 11:27 PM
dacaur
dacaur's Avatar
Here is the thread http://www.rcuniverse.com/forum/m_46...tm.htm#4689554
and no it doesn't use deans connectors... i got an adapter with the mini quake battery connector one one end and a deans on the other at my LHS for a few bucks.....
barefootdan
an adapter only to charge though
Old 11-13-2007, 11:28 PM
barefootdan
CONFUSED?!?!? lol
ok so i get a deans for the mini quake.
then a tamiya so i can use my charger.
correct?
Old 11-13-2007, 11:30 PM
barefootdan
unless there is a good charger (cheap one)
so i need no adapters
Old 11-14-2007, 12:11 AM
dacaur
dacaur's Avatar
the mini quake doesnt come with deans connectors. this is what it has http://www3.towerhobbies.com/cgi-bin...?&I=LXJNS3&P=M
Old 11-14-2007, 12:26 AM
walkingcarpet900
buy what ^^^ says
solder the female one to a deans female and the
male connector to a deans male
Old 11-14-2007, 09:05 AM
barefootdan
so then i can get an adapter for my battery that allows me to use my quick charger?
Old 11-14-2007, 01:07 PM
rschoi_75
rschoi_75's Avatar
If all you are looking for is to charge your MQ with your quick charger get this: HPI Micro male to Tamiya female adapter.
I think all the other guys are confusing you with talk of multiple conectors.
Personally, I would change everything to deans and just be done with it. If you don't know how to solder, the guys at your local hobby shop should be able to do it for you. If you know how to solder, the entire switch will take 10 minutes to change all your trucks.
Old 11-14-2007, 01:12 PM
barefootdan
why are deans better??
do the not break as easy?
Old 11-14-2007, 01:29 PM
rschoi_75
rschoi_75's Avatar
They are better because they are considered a "no loss" connector. "No Loss" means the resistance of the connectors is less than the wire you are using.
HPI micro and Tamiya connectors have higher resistance, and will act as a bottle neck for power flowing through them. Which is why people melt those crappy hpi micro connectors all the time. All that resistance leads to heat build up (the energy has to go somewhere... i.e. heat). The tamiya connectors are better, but still reduce the power actually going to your motor.
Other "no loss" connectors:
- bullet plugs
- Powerpoles
- TRX plugs
- Hardwiring
Old 11-14-2007, 04:36 PM
barefootdan
what do you recomend would be the easiest?
is crimping ok?
Old 11-14-2007, 04:45 PM
barefootdan
is there a connecter that goes from deans to tamiya?
that is probably the esiest huh?
Old 11-14-2007, 04:51 PM
barefootdan
is [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSG85&P=7]THIS[/link] a good charger?
or [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAKC3&P=7]THIS[/link] to use my own charger
or is it [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNGB7&P=7]THIS[/link] connector?
Old 11-14-2007, 08:49 PM
rschoi_75
rschoi_75's Avatar
I just use deans ultra plugs on all my batteries. They are incredibly easy to solder. Crimping is a definite NO. It will cause tons of resistance.
The charger you linked is not to be used for 2/3A batteries (mini batteries). Its for Sub-C only since it only has one charge rate @ 4a. Mini packs should be charged between 1 - 1.5 amps on average.
I'm really confused about your connector questions. What are you trying to do? which charger do you have? Let me see if I got this straight.... Your charger has a Tamiya connector on it (male I'm assuming). You want to use deans on your MQ batteries. If so, the last link is the correct one. You need a Female Tamiya to Male Deans adapter.
Old 11-14-2007, 09:03 PM
barefootdan
YEAH UR RIGHT
GRATS
lol
