where can i get a bl moter and a carrying case?
IL
Hi guys,
i was wanting to know where can i get a bl moter for my detta? Also where can i find a cheap carrying case?
Thanks: savycharlie
MO
RE: where can i get a bl moter and a carrying case?
im having trouble finding one for my micro t i know losi makes them the for 1/10 and 1/8
i think im prolly just going to end up making one myself
other than that i would probably say call your lhs and have them special order you one if they know of any
Check out Tower Hobbies. You can get bl motors and a carrying bag there. Duratrax makes one for 1/18th size vehicles.
IL
Thanks guys! What i think i am going to do is i have a mamba bl moter and esc. As you all know they over heat. I am going to put a heat sink in it. That is the reason i wanted to find a different bl moter but know my problem is solved.
Well, the overheating part isn't the biggest concern with mamba motors. Its the shaft size / pinion option issue. The only pinions you can use with a mamba in a vendetta (or mini quake) are the atomic 2mm pinions. Normal vendetta pinions are 2.3mm bore, which will not fit properly on mamba or other 2mm shaft motors. You'd be better off getting an Ammo 28-35-3900 or 28-35-5100 motor. Those use 3.17mm bore which can use a much wider variety of pinions. Robinson Racing makes the correct pinions for those motors and can be bought at Tower Hobbies as well. Look for the 48p metric pinions from Robinson.
