OFFICIAL CEN MG16 THREAD
#276
FL
RE: OFFICIAL CEN MG16 THREAD
I was thinking to get the aluminum upgrade that cen have for the shocks, do you think this is a good buy or will be better to get a new whole set and replace the stock ones?
#278
MI
i was going to use an OS 18 with a short shaft crank. Then you would only need the clutch adapter CEN offers.
Otherwise use the 3.0 from CEN?
#279
WI
The OS 18 might be a bit much for this truck IMO, I put one in my mt2 and it chewed up diffs like crazy. and the MG16 dont really have the strongest drive line to begin with. but if you could find a stronger center dog bone and better diffs that thing woul be a insane little ball of fury
#281
My Feedback: (37)
So what exact crank would you need to fit the OS 18 in this truck? The standard crank with the CEN MG095 adapter or the shorter one? I have seen different opinions on which OS 18 engine. I just ordered one of these trucks and of course interested in upgrading the engine even before receiving it. Check this engine upgrade out!!! http://www.youtube.com/watch?v=ocoDnsQVpFI
This is the one I remember being posted somewhere. http://www3.towerhobbies.com/cgi-bin...?&I=LXGGP6&P=7 . Thanks in advance.
#282
Hi, first post and its in an oooold thread sry about that but i found my MG16 for some days ago and now im interested in convert it to electric,looked ata clip on youtube and liked it alot
Can you help me?I dont know mutch about these things sois it possible? will it get expensive? and what do i need?
Doesent need to be the fastest car or anything, china parts will do to keep the costs down.
Best regards /Jimel
EDIT:will this work? http://www.focalprice.com/YOA95X/Hob...ersion_20.html
Best regards /Jimel
#283
MI
ORIGINAL: jimel77
Hi, first post and its in an oooold thread sry about that but i found my MG16 for some days ago and now im interested in convert it to electric, looked at a clip on youtube and liked it alot
Can you help me? I dont know mutch about these things so is it possible? will it get expensive? and what do i need?
Best regards / Jimel
EDIT: will this work? http://www.focalprice.com/YOA95X/Hob...ersion_20.html
This EZRun bl looks about the correct KV for this size of a truck.
Good luck
#284
Thank you so mutch for answering, ok will look up the parts that are different and have a look at the MG chassie and try to find out if i need something from the ME, too bad i suck at evrything about this but il have to learn step by step.
The motor wont be too weak? i have no idea
#285
MI
ORIGINAL: jimel77
There is an ME thread i was a part of years ago if you search it. It will have much usefull info on BLs in this platform.
AS far as the conversion, i think just the chassis, radio box, center shaft, body, and motor mount were different... i think...
here are two threads. I have a few vids of these also on YT.
http://www.rcuniverse.com/forum/m_85...tm.htm#8595760
http://www.rcuniverse.com/forum/m_72...tm.htm#7288770
#286
OK so about a year later I am sort of finished, it works but i need to work on battery placement.
Maybe no one is interested but just wanted to show that i really went throu with the project.
PICS!!
Teardown
Some parts
Building
Action pic (sorry for rotation)
EDIT: Video
http://youtu.be/0-SYT4PHtQ4
PICS!!
Teardown
Some parts
Building
EDIT: Video
#288
CEN MG16 engine work car stays
Dear I do have problem, engine works, accept gas but stay.
What kind of problem could be between engine and wheels? Spur gear also stay, do not rotate.
