Need gearing recommendations for Mamba-fied RC18B
My Feedback: (36)
So I'm converting one of my Associated RC18Ts to a buggy, and since I had to take the top plate off I had a chance to inspect the diffs and gears. The outdrives are a bit chewed up as well as the input and diff gears. I figure now is a good time to replace them. So I have a few questions for you guys:
Is the MIP super differential a good piece?
How about the Delrin geared differential from GPM? Better/Worse than the MIP diff?
Are the MIP CVDs the best CVDs offered for the RC18? Are the worth the expense over the aluminum dog bones I currently have?
Finally, what gearing should I go with? 55t or 60t spur? Which pinion? For reference my car has the Mamba 6800kV setup and is powered by 7.4v 2200mAh Li battery.
Thanks!
Thanks!
CA
RE: Need gearing recommendations for Mamba-fied RC18B
ORIGINAL: ptgarcia
Thanks!
Thanks!
#2, cvd's, go with them, super tough... won't bend under the force of the brushless setup
#3, if you want blazin fast acceleration go 10,60. for speed, 15, 55, as for a good setup, hard to say, get a bunch of pinions, and a temp gun and do some "gearing tuning", should help, I run my RC18MT (converted to a T), at 15, 55 and get good acceleration and speeds (running a stock motor [X(]0, hope that helps, if you say what you are after with the gearing, speed, aceleration... then i can help more[8D]
My Feedback: (19)
What set-up I been using is the 55t w/ the 10t pinion {I got the 8000 }which gave me stupid speed basically to drag race;I had to use the mamba usb to alter the speed set-up.I use a lipo 3c 2200 pack.The MIP super diff helped me not to tare the diff's up after i adjusted the throttle I'm having a ball and never had to change it since.Never tried the delrin gears but I hear their also as good if not better.IMO.Hope it helps you out.
My Feedback: (36)
Does the MIP super diff come with the gears and balls and any other internal part?
Right on, thanks for the help, guys.
To answer calvino's question, I won't be racing this buggy, just driving around the house and in campgrounds and such. So just a general purpose gear ratio is what I'm after. One not great at anything, but good at everything.
CA
Yeah get the MIP supper DIFF. Also IMO you need [link=http://www.thetoyz.com/cart/thetoyz_details.lasso?id=9388&cat_name=RC18T]these steel input and ring gears[/link]
and while your at it get the [link=http://www.thetoyz.com/cart/thetoyz_details.lasso?id=9034&cat_name=]56T titanium Spur gear[/link]
These upgrades just made my RC18 my favorite car again just because it's bullet proof now.
