MLST2 + mamba comp 6800 = what do I need?
I want to pick up the 6800 comp set at my LHS but I was just curious what I will need to make the conversion to BL. Obviously I will need one smaller pinion, any size suggestions? What about mounting it on the stock motor mounts, do I need an adapter to make it work? Any other usggestions? Thanks.
RE: MLST2 + mamba comp 6800 = what do I need?
ORIGINAL: t9dragon
I will mount right were the stock motor is mounted. Make sure you have plenty of extra diffs. Also you will want a center ball diff and the dual disc slipper.
It is the Losi Dual Disc slipper for the Mini-T or Mini-LST. I was running a Mamba 8000 in mine with the stock plastic front and rear diffs without any problems, but I think the diffs have held up just fine becuase of the dual disc slipper.
im in the process of doing my mini lst now. mamba max system and 3 cell thunder power lipo. first run blew both rears. steel ones are on order!
