micro rs4?
micro rs4?
In the description of this car, it says it has solid diffs for drifting. What does this do for drifting?
Does this mean that I cant make a tire swap and unplug the D-box and run it like a touring car?
Also, what are the stock speeds of this car? What would it take to get it into the 50mph (60mph if possible) range?
OH
RE: micro rs4?
ORIGINAL: supamagician
You would definitely want regular open diffs if you wanted to use it as a touring car. It would turn/handle much better.
Stock speed isn't super fast, but isn't terrible for what it is. I think 50-60 MPH would be very difficult unless you had a perfectly smooth surface. The car doesn't have a whole lot of suspension to absorb bumbs at speed. My buddy has a Micro RS4 with a brushless motor and a 2 cell Li-Po. Nowhere near 50MPH (maybe 30-35MPH) and it is a handful. Not saying it couldn't be done, just might not be the best car for it unless you have a super smooth surface to drive it on that is big enough to use that kind of speed.
