max charging amps
VA, AMERICAN SAMOA (USA)
max charging amps
fror this aero nut battery http://www.aero-nuts.com/product_inf...roducts_id=454 its in a mini t im charging with this charger still try ing to figure it out http://www.aero-nuts.com/product_inf...roducts_id=559
CA
RE: max charging amps
Never exceed 1C when choosing the amperage to charge a Li-Po battery unless directed to by the battery manufacturer.
This means that you charge the battery at a rate based on the mAh of the battery you are charging.
Examples of 1C = 2300mAh @ 2.3 amps OR 4500mAh @ 4.5 amps OR 500mAh @ 0.5 amps... etc.
