OFFICAL RC18R THREAD
#52
CA
RE: OFFICAL RC18R THREAD
He was talking about calibrating it, which is easy.
actually programming it is pretty easy too, just read over the manual a couple times, its pretty simple.
#53
CA
ORIGINAL: deanR
and lancer123...you need to chill out dude people make mistakes
#54
CA
Does anybody know the differance between the 3Racing shocks and TheToyz shocks? Both are threaded alum and both are 50mm in size. Both are the same price on Thetoyz.com at $24.99 a set but TheToyz ones are instock the 3Racings are not. Im planning to order a couple of items and would like to get everything at one time.
Heres links to the said shocks:
TheToys shocks = http://www.thetoyz.com/cart/thetoyz_...8705&cat_name=
3Racing shocks = http://www.thetoyz.com/cart/thetoyz_...8770&cat_name=
#55
dude wth.. i am chilled out ...i am not yelling at you or anything ...i am not using any caps or exclamation marks .. haha
and yea programing is super easy it worked on my first try ...read through it slowly like 3 times ...with good concentration like when oyu are pooping and you will know how to do it w/o any problems ...
#57
Also I have had this problem with my steering. When I straighten out the trim later I have to adjust it somewhere else later. Its extremely annoying and if i go brushless this will be a serious problem.
#58
CA
ORIGINAL: Wepo
#70
Well I just zip-tied my servo saver. And ordered the drag link so I should have a significant improvement. Ill order the new batteries tomarrow so then i think ill be set for brushless which im getting in november.
#72
CA
Well i sent in an order at thetoyz today! got two draglinks coming *finally* and 2 sets of thetoyz shocks(comparable to the 3racing set). now i gotta find 2 good 2 or 3 cell lipos for under $50 each and i should be good for awhile. Any suggestions?
#73
Dont forget about him but,
How is that orion battery? I saw one at my lhs but I have always used the elite packs from cheap battery packs. Thay are 100mah apart but I think they would put out the same performance.
#74
CA
ORIGINAL: Mousesi2k
