nitro mini lst2
RE: nitro mini lst2
ORIGINAL: Mr. Mugen
Yours? If so, details?
I wish it was mine...........................
I found that pic on a forum several years ago. To bad that forum doesn't exist anymore because it was a great forum for the minis...........................
FL
RE: nitro mini lst2
I'll try and get some more pics of the underside that will show most of how I did it. I'm not the best machinist in the world. I'm a dremel man.
FL
RE: nitro mini lst2
was running it this evening and launching it off a ramp and no problems yet. It is an mlst2 and if its holding up brushless than its got to be good for a little .o5 motor.
RE: nitro mini lst2
ORIGINAL: QUADS ONLY
looking for a spur gear though maybe someone would know where I could find a 43 tooth 32 pitch ?
Kevin
FL
RE: nitro mini lst2
the sportwerks chaos spur is what I'm using. its a 50 tooth but I'm not exactly sure on the pitch. If I cant find a small spur I'm going to try a picco motor.8cc and a nt18t clutch bell set up. Just to get some more top end.
FL
RE: nitro mini lst2
[/quote]
I may have one here for a old Kyosho. I have so many parts for those I will take a look.
Kevin
[/quote]
I would appreciate it very kindly.
FL
RE: nitro mini lst2
I found a 32p 43 tooth robinson gear but nobody on the planet can locate one. I have one on backorder and has been for 3 months now.
RE: nitro mini lst2
I think this is bigger than 32p....it is for a MTX3. I have many sizes of this spur and only one pinion....not for nitro though..obviously. If you can find out the pitch of this and it works out for you it's yours.
Kevin
Kevin
RE: nitro mini lst2
Shoot.,....just pulled the 32p pinion drawer out and found the stash of 32p pinions I have had forever....not the one you need. Sorry to get any hopes up man....I haven't used 32p in so long I forgot how they looked. Now I know where all my Optima spurs and pinions are...lol Hey maybe the Big Brute has a size near that. Will look for it's bin next.
Kevin
Kevin
