mini dt range issues
LA
how to get better range out of the mini dt it seems like only 50 feet then it quits,
is it worth putting the trans bearings in, does it make a differance?
thanks
thanks
ID
RE: mini dt range issues
just to make sure, but your antennae is in the right spot right? My antennae tube kept falling out, so I took it out and routed the antennae around the inside of the body. this did not work at all! it took my range down to about 40 or fifty feet! you might also check and make sure it did not seperate or anything. just some thoughts!
