Mamba 1/18th micro pro help please!!!
CO
So i have the micro pro 5400kv combo and Im trying to get things setup. Im using a nimh battery but have some lipos available. When i turn on the esc and try to calibrate or go into the programming mode i get the four musical tones then continuous beeps and red flashes on the led. No throttle but i have steering control. Im guessing i cant use castlelink since theres no usb connection...sucks i wish i wouldve realized that. Im just trying to get something. Using the stock radio equipment what am i doing wrong? open to all suggestions help me out guys!!
WI
RE: Mamba 1/18th micro pro help please!!!
Just incase you haven't figured this out yet. I'm sure there's an adapter that plugs into it with a usb on the other end so you can use your castle link. I have the 25 and the Mamba max and use the castle link with both. You should find what you need here. http://www.google.com/products?hl=en...ed=0CBUQrQQwAA
