RC18MT Crawler
Would and if possible how would I make An Associated RC18MT a rock crawler but still capable of driving on a dirt trail?
RE: RC18MT Crawler
Only if you'r good with making a lot of custom parts.
RE: RC18MT Crawler
if you could modify the toe and camber links to increase travel and by making/buying super long a-arms.
that would help. |
RE: RC18MT Crawler
So in english no[:o]? Oh well I guess I'll stick to dirt off-roading
Nasher |
RE: RC18MT Crawler
Nope. Solid axles are a must.
RE: RC18MT Crawler
you can do things to make it crawl better but it couldn't ever crawl well. so i guess its a no.
RE: RC18MT Crawler
Nasher
i dont know how good of crawling capabilitys you want but watch this video and decide for yourself if this is what you want http://www.youtube.com/watch?v=VBgKJtgkF3M nuke_24 |
RE: RC18MT Crawler
I got the B and noticed I can actually crawl!
Nasher |
RE: RC18MT Crawler
is a solid axel one of those axels which go down from the drive train to the wheel mount thing?? like a normal drive shaft only it bends in two places and is outside of the chassis??
RE: RC18MT Crawler
A solid diff is the outdrives and the outside gear that the driveshaft comes in contact with is completely solid so there aren't gears or balls or anything.A solid diff is the same as a locked diff and is usaully used on a wheely vehicle likes HPI's Wheely King.
Nasher |
RE: RC18MT Crawler
crawling is more than being able to climb over a carefully arranged sequence of objects.... a solid axle means that you dont have arms in the suspension, the wheels are held rigidly to the gearbox and its the gearbox that moves
http://en.wikipedia.org/wiki/Solid_axle one advantage of solid axle is that the vehicle would act more like a pair of lines, like one line representing the front wheels and another line representing the rear wheels... in an independant suspension setup like what you have in your 18mt, the whole vehicle would hold a rectangular shape and it would not be flexible enough for true rock crawling |
| All times are GMT -8. The time now is 12:31 AM. |
