Radline rc 1/24
1 Attachment(s)
So has anyone scene these cars yet or have you purchased one. They say that the Master series comes with an adaptor so you can put a 180 can in them.
http://www.radlinerc.com/index.html Any opinions as of yet. Check out the youtube video http://www.youtube.com/results?search_query=radline+rc |
RE: Radline rc 1/24
Yeah, somebody posted a thread about these a while back.
RE: Radline rc 1/24
I have the buggy, its a bit of a pain because it eats regular AAA batterys alive...its almost a nessesity to get rechargable batterys. For a little 1/24 its pretty durable, i jumped it off by dad's F-150 and it drived away fine just had to pop the right shock back on. I would recommend them to begginers (It was my first rc)
RE: Radline rc 1/24
what about using lithiom batts.. i wonder how the esc would handle them..
RE: Radline rc 1/24
The local Hobbytown got a bunch in. I don't remember exactly which ones, but I do remember that that were different that the radlines I've seen at Target. Looked nice from what I saw, but I didn't really scrutinize them as I was looking for MLST parts at the time...
RE: Radline rc 1/24
must have been the elite edition. Uses real 27mhz and 6 crystal like -
Plus you can put a 180 can in them for some real speed. I hear something like 89.99 I think I'll have to pick up one from Target and give a review of them |
RE: Radline rc 1/24
I have the Elite stadium truck. You can make them very fast and precise. I upgrade to full bearings, aluminum shocks, 1,000 mah recharchables and a 180 motor. I had two extra 180 motor left over from my apache heli upgrade. Had to trim the motor holder a bit. Running a 13 tooth pinion and 32 tooth spur. I just ordered the master series stadium truck. I comes with all the above upgrades already installed and a better radio. I am puttting an Xtreme 180 motor. I only payed $61.00 for the Master series truck and $49.00 for the Elite before upgrades. Making a small track in the back yard to run the trucks my 5 year old son.:D
RE: Radline rc 1/24
i want the ST. ill probably get it for the holiday so i dont have to spend any money :)
RE: Radline rc 1/24
I absolutely hate mine drove it twice and it's been sitting since
RE: Radline rc 1/24
well there are two dif kinds
the Master's and the Elite the Elite are sold at Target for like 49.99 which are the ones shown in thoes videos, i had they are ok, i supped mine up, u can see my videos in the "related vide section off that link" but the stock dif blew up Tower is selling the Master's and are now avaible they are like 67 bucks, i think i might pick one up to see what that is like here are the specs http://www3.towerhobbies.com/cgi-bin...&P=IA&I=LXRNU2 and http://www3.towerhobbies.com/cgi-bin...?&I=LXRNU1&P=M Specs on each type Elite: RADLINE RC’s ELITE SERIES---fast, fun, responsive 1:24 scale vehicles that prove big things can come in small packages! With all the excitement, detail and technical innovation you’d expect in larger scale, our All Wheel Drive ELITE SERIES is equipped to compete---right out of the box! SCALE: 1/24 TRANSMISSION: 4WD TIRES: Off-Road w/foam insert SUSPENSION: 4 Wheel Independent Wishbone PRE-INSTALLED MOTOR: 21,000 RPM FC-130 SPEED: Up to 240 scale MPH RADIO SYSTEM: Race up to 6 cars at once---AM 3 Band, 2 Frequency (29 & 49 MHZ) TRANSMITTER FEATURES: Steering & Throttle Trim, Band Select, Torque Control RECEIVER & ESC: MOSFET Power Control IC, Over Current Protection Circuit, LED Band Select Indicator, Band Select Switch CONTROL PROFILE: 31 Step Digital Proportional Steering & Brake CHASSIS: RADLINE RL4 POWER SOURCE: Transmitter 1x9v, Car 4xAAA (*Rechargeable batteries recommended) AVAILABLE EXCLUSIVELY AT TARGET stores RETAIL $49.99 Need even more excitement? Check out our UPGRADE & REPLACEMENT PARTS! RADLINE RC’s MASTER SERIES---If you’re an experienced RC enthusiast looking to really compete, give our MASTER SERIES vehicles a test drive! Their “Master” grade components deliver a faster, more maneuverable product you can modify and maximize into a true high performer! SCALE: 1/24 TRANSMISSION: 4WD TIRES: Off-Road w/foam insert SUSPENSION: 4 Wheel Independent Wishbone PRE-INSTALLED MOTOR: Hi-Rev 180 SPEED: VARIABLE (Dependent on motor type used and installation of performance components) RADIO SYSTEM: Race up to 6 cars at once---FM Transmission, 6 Band, Single Frequency (27 MHZ) TRANSMITTER FEATURES: Steering & Throttle Trim, Band Select, Torque Control, Steering/Throttle Reverse Switch RECEIVER & ESC: MOSFET Power Control IC, Over Current Protection Circuit, LED Band Select Indicator, Band Select Switch, “One Touch” ESC Throttle Setup, 3 level Brake Strength/Motor Frequency Select, No limit to 130 Type motor upgrades CONTROL PROFILE: 128 Step Full Digital Proportional Steering & Brake for precision control CHASSIS: RADLINE UL-01ST POWER SOURCE: Transmitter 1x9v, Car 4xAAA (*Rechargeable batteries recommended) PERFORMANCE UPGRADE FEATURE: Factory Installed Ball Bearings for friction reduction, chassis can accomodate FC-130 and Hi-Rev 180 motors using included special adapter sleeve AVAILABLE AT FINE HOBBY RC STORES NEAR YOU---RETAIL $89.99 Need even more excitement? Check out our catalog of UPGRADE & REPLACEMENT PARTS |
RE: Radline rc 1/24
Well i just ordered the Master Pincal Stadium Truck, should be here by Tues-or wed. The Elite Detour Truck was fun but to much of a toy, untill i upgraded it, but i then i brok difs, so hoefully the Master Pincal Stadium Truck is much better, i have high hopes for the Master based of how fun and strong the Elite was. =] So i will post a review and some pics when i get it, im going to keep this stock besides swapping out the stock servo for my HS55 it says it is 3-wire servo compatable
RE: Radline rc 1/24
I ordered the same stadium truck yesterday. Got it here: http://www.hobbylinc.com/htm/unx/unx424991.htm
What motor were you running in the Elite that chewed up differentials? I am running a pretty hot 180 motor with zero problems so far. I also ran radlines mofidied motor previous to the180 upgrade. |
RE: Radline rc 1/24
Radline Elite ST,
High performance motor, 5 cell aaa pack, novaik ESC, hs55 servo, futaba rx. this is mine http://www.youtube.com/watch?v=ogdmpM-exKA http://www.youtube.com/watch?v=-S17Lr4nKIM the dif snapped a tooth when i landed a jump still on the gass, one tooth on the rear dif broke off, i think it might of been the landing combined with the extra power from 5 cells instead of 4 cells... but im looking forward to getting mine, i ordered it mine from Tower |
RE: Radline rc 1/24
Thanks for the reply Joey. One more question. How did you add the 5th tripple A? I would like to do the same. Thanks
RE: Radline rc 1/24
ORIGINAL: joeyblaze Radline Elite ST, High performance motor, 5 cell aaa pack, novaik ESC, hs55 servo, futaba rx. this is mine http://www.youtube.com/watch?v=ogdmpM-exKA http://www.youtube.com/watch?v=-S17Lr4nKIM the dif snapped a tooth when i landed a jump still on the gass, one tooth on the rear dif broke off, i think it might of been the landing combined with the extra power from 5 cells instead of 4 cells... but im looking forward to getting mine, i ordered it mine from Tower |
RE: Radline rc 1/24
ORIGINAL: triggeraa Thanks for the reply Joey. One more question. How did you add the 5th tripple A? I would like to do the same. Thanks i made a pack that had 3 on one side 2 on the other side, i had to hollow out the stock battery trays. i doubt Xmod difs woudl work they seem to small. |
RE: Radline rc 1/24
RE: Radline rc 1/24
ORIGINAL: zjwhitrock how bout adding AAA lithium??:D avalable at www.atomicmods.com yes i know ther expensive |
RE: Radline rc 1/24
Just added a 7.4, 1000 mah lipo. Combine with a 180 motor and full bearings, it runs like a rocket. The wheels are the weak link. Broke 2 wheels already while crashing under full throtle. The little connection tabs busted off.
RE: Radline rc 1/24
ORIGINAL: triggeraa Just added a 7.4, 1000 mah lipo. Combine with a 180 motor and full bearings, it runs like a rocket. The wheels are the weak link. Broke 2 wheels already while crashing under full throtle. The little connection tabs busted off. |
RE: Radline rc 1/24
maby we can find a way too use losi's new excelaron brushles:eek:
RE: Radline rc 1/24
ORIGINAL: joeyblaze ORIGINAL: triggeraa Just added a 7.4, 1000 mah lipo. Combine with a 180 motor and full bearings, it runs like a rocket. The wheels are the weak link. Broke 2 wheels already while crashing under full throtle. The little connection tabs busted off. |
RE: Radline rc 1/24
Yeah my masters should be here tomorrow :) im excitded
i all ready took the Alum shocks off my ellite, and took out the high performance motor out, even tho im sure the stock 180 can will be faster then the 130 high performance |
RE: Radline rc 1/24
Well it came in the mail today, im exctied to get home from work and check it out, however i wont be able to get pics ro review it its me and gf 4 year tonight, so im taken her out to diner. :) but stay tuned
RE: Radline rc 1/24
My Masters series truck came today as well. Replaced the stock 180 with a "performance" tuned 180 and a 7.2, 1000 mah lipo. Instant wheelies and plenty of speed.:D The truck also lost 11 grams due to the changes. My next project is a wheelie bar.
http://cgi.ebay.com/E-Flite-Blade-CX...QQcmdZViewItem |
