Which Iron
Me thinks this should have gone in the last post but never mind,,, what power soldering iron should i use to solder the cells together to make my own pack?.
Cheers Mark |
RE: Which Iron
I solder at 45 watts. Anything over 40 should be good.
RE: Which Iron
I usually use 45 watts of power.
RE: Which Iron
for just wiring (motors/escs) i use a 60watt iron
for batteries i use a 100 watt gun the thing is with batteries is that u need a iron/gun that can heat up the surface of the battery fast enough without overheating the actual cells also besure to scuff up the cells contacts (a lesson i just learned =P) for a better bond and to use flux anything above 40 should be good if it is a good quality iron not one of those cheapy ebay china ones but a good radioshack or weller one my 100watt gun gets hot very quick in about 9 seconds when i pull the trigger thing i like about guns is that it only gets hot when u pull the trigger so when ur not working with the iron right @ the moment, it wont burn anything |
RE: Which Iron
Ya. Carpet learned about burns the hard way. And yes, a gun is better. I used to have one, but sold it an with a little more pacients you can oldier just as well with a 45 watt, good quality iron. Oh, and get a soldering jig. :D
