Cox .020 Glow heads are now available!
My Feedback: (10)
BC, CANADA
We now have Cox .020 glow heads in stock:
The combustion chamber was designed for the Tee Dee version but they will make Pee Wee engines really perform
Bernie
www.coxinternational.ca
My Feedback: (90)
RE: Cox .020 Glow heads are now available!
ORIGINAL: Big Al-RCU
Was there a difference between the Pee Wee and the Tee Dee heads? I never was able to see a difference.
Al
Al
Dennis
My Feedback: (90)
Can't help you with the part number. I don't even have a head. But you'll know you have one. It has the same ridged ring around the top of the plug as the 049 high compression [plug. Since it hasn't been available for about 20 years it is no suprise that the part number is long gone.
Perhaps Larry Driskol can help us here.
My Feedback: (10)
BC, CANADA
Big Al,
Cox used to make a high compression 020 head for TD engines. In the 90's they stopped making that one and used the regular head on their TD's. It was slightly modified to make it more like the TD one.
Ours is modelled on the old TD version and actually outperforms the high compression one Cox once made.
Bernie
Bernie
My Feedback: (50)
CA
Bernie,
First, I'd like to say that it is great that you are offering this part to help keep the .020's running!
Regarding the original use of high and low compression heads on .020's:
Many early Pee Wee's ORIGINALLY came with HIGH compression heads.
Towards the end, both Tee Dee .020's and Pee Wee's came with LOW compression heads.
This was discussed here quite some time ago:
http://www.rcuniverse.com/forum/m_20...tm.htm#2091648
Bottom line: I think offering .020 heads in only the high compression version was a good choice.
