Another Kadetito Build
RE: Another Kadetito Build
Then
The idea of ​​using ultracote is good.
My idea is to use ultracote transparent..
I using this ultracote not have problems.Am I right? http://www.hangar-9.com/Products/Def...ProdID=HANU966
ORIGINAL: hllywdb
................In the last 10 years I have covered all my 1/2a planes with Ultracote. I goes on easier, has less chance of warping the wings, and is 3 to 4 times stronger so if my plane bounces around a bit in the car or on a less than perfect landing I don't have to fix holes. Is it heavier? Yes, but in weight measured in grams.
Given the size of most of the 1/2A planes, a little calculation on the area to be covered will show that covering weight is really fairly insignificant - in many cases, less than .5 oz. Like Bill posted, simply choosing a different battery pack or tank will usually make much more difference in weight than using a different covering.
I agree, but this model airplane is an area of ​​approximately =1.5m² = 16sqft
monokoteTOPQ0304 Weight = 0.2 oz / sq ft (61 g / m²) = 90grs=3,17oz.
ultracote Weight: 0.12 oz per square ft (36.6 g / m²). = 54.9 grs=1,94oz.
(90 -54.9) = 35.1 grams = 1.2 oz.
UT
Good information here, thanks guys. I'll be posting more pics of progress. I've been on the road working...but will be home tomorrow. Perhaps I'll have a couple of hours to work on the plane over my next 3 days at home.
#31
Looking good, sirzepp. I have a question about the dihedral in the wing. I am working on a Kadetito also and on the plans I have there is no actual figure for the amount of dihedral. Measuring the angle of the dihedral brace with a protractor I get 9.5 degrees. Is there a figure on the plans you have?
#35
I expect you'll be OK with the dihedral, sirzepp. I checked a model design book I have, and for a trainer, an angle of 6-8 degrees was specified for 3 channel trainers. Think I'll go with 9 degrees. A little bit either way probably won't matter.
#36
UT
Fuse sides done:
Fuse assembly:
I made my first big screw up above (there have been a few little ones). I used a 1/4 inch ply firewall...for some reason my brain was convinced it was the right size (1/8")...I've had a lot on my mind lately and even though it looked too big...I installed it without reassessing. So now I can but a 30cc gasser on the front of my kadetito. Dear Lord, I think I'm going insane. Anyway, it shouldn't matter TOO much, I'll just move the battery back. The bummer is, I'm using an ultra light LiFe battery, and I just counteracted that weight savings...lol. But I am too lazy to fix it.
Mocked up:
Fuse assembly:
Mocked up:
#38
UT
Fuse is nearly complete. Just a few more things to do.
Still have to build the vertical stab and rudder, then it's time to prep and cover.
#42
UT
Got the fuselage sanded, installed the cowl, engine mount (and mocked up engine, obviously...which is where I started making airplane noises!). Hinged control surfaces and started mocking up servo placement. It's getting there, but the electronics installation and control rod routing is always where I bog down...I don't find it enjoyable at all. I'm looking forward to covering, but until I get the radio squared away I have to wait...UG.
#44
ORIGINAL: skaliwag
No Dear ..... This week we have a Kadet. Next week you have the Cupid. Then I have my Dooling '29 , and for the week your mother is here you get to choose again..
#46
My mother-in-law is 81, doesn't mind 1/2A centerpieces, and occasionally goes up to the field with us to get a little stick time in on the buddy box. If your mother-in-law doesn't get the centerpiece thing, take her to a swap meet and trade her for a couple of good running TD's or something
#47
UT
You guys gave me a good laugh! Love that. Luckily my mom-in-law is an incredible woman...so glad to be married into their family.
Not sure she'd be down with 1/2A centerpieces, though...but a couple of TDs do sound nice.
#48
UT
She's up on her own legs now. Servos are installed, pushrods routed, engine mount ready...getting really close now...
Wheels are dubro ultra lite foams...front one is a bit smaller, but they are all kind of big because I want it to be able to fly off reasonably mowed grass. My dad doesn't have access to a formal field, so he'll be finding a place out in the boonies...and I want him to have all the options he possibly can.
#49
It looks terrific. Over-sized wheels are excellent on grass, especially for small airplanes. It's amazing what will take off from a rough field if you just make the wheels big enough.
Jim
Jim
#50
Looks great so far Sirzepp.
Can't tell from the picture, but you want to make sure that the landing gear setup keeps the wing level, or even just a tad down, otherwise they just keep bouncing and trying to take off again when you try to land them
