Cardboard Delta Pics
Take 2 hours, 1 sheet of cardboard, 1 roll duct tape, a few tie straps, and misc RC parts, mix togeather, fly. Sorry I don't have finished pictures but the only things missing were the taped on rudder, radio, and battery. I flew it a few times but the problem was the tape coming off in my hot garage. Overall I'm pretty happy with this little experiment.
[link=http://www.fxprojects.com/cardboardflyer/]The rest of the pictures[/link]
BTW, nobody has a smaller workbench than me.
enjoy,
Mike
enjoy,
Mike
RE: Cardboard Delta Pics
My high eccurate technical answer is... really light. Seriously I don't know but the cardboard is just your standard stuff not anything heavy duty. 2 micro servos, The Cox engine, standard 6 channel reciever, and a 200-something mah battery. Crazy light would be an understatement.
If I used something like the sticky tape used to do stripes... the good stuff... a plane like this might come out quite nice. I don't think that type tape would come off in a hot garage.
NC
Mike,
Oh that looks so cool! What a neat idea. I've got a supply of 2 Mil Coroplast that is looking for a project.
Could you provide some dimensions? I wouldn't need more that length, width, and location of the prop slot - and CG.
Appreciate it.
Appreciate it.
NC
how small is your work bench???mine is 24 by 48 in.and it sits in my lap on the couch...it's a ceiling tile on a peice of plywood...
john
john
Raymond:
24" span and about 32" to 34" length. engine is about 2/3 back. To tell you the truth I didn't put any serious calculations into this project and that was the biggest size I could make it with the box I had. You have about 15 inches to move the battery and radio for and back to CG it. I tested the CG by tossing it on my lawn until it seemed right. Don't forget to added a vertical fin. Radio/servos/batter were double side taped as well as tie-strapped.
jboy:
You got me on the poor location of the work bench but mine is only 24 x 40 and a quarter of that is tools. It is quite nice and sturdy though.
jboy:
CG? Sorry I didn't record or even ballance it. Just tossed it onto my lawn and moved the batter/reciever until it seemed right. Don't you just love my building and flying technique. The 200-something mah batter and reciever were about 8 inches from the nose. I don't know if it's normal for a delta but slight up elevator trim was required.
I thought it was kinda silly but now that a couple people seem interested I might try to build one again. If I do I'll make sure I record all the important stuff and post it here.
Any flying wing, deltas included, require some reflex in the airfoil camber. Even if the main part is symetrical (ie: flat like this one) you still need some reflex for it to be stable. The slight up elevator trim fills that function.
You can see the same up elevator on things like Zagis as well.
You're not missing anything. That's right. Cardboard started getting fuel in it, duct tape started coming off, started getting banged up from my amazing cartwheel landings, etc. It was never intended to be anything execpt a disposable experimental project. Flew about 6 times only. Fuel soaked or not it would have lasted longer but the real problem was the tape coming off. Better tape next time.
Not necessarily. Right after applying the tape, apply some kind of paint or varnish all over the wing, once or twice. This should prevent this tape from coming off !
BC, CANADA
Mike: Great idea, thanks for sharing. Try book binding tape on your next one, get it at stationary stores. The amount of fun is directly related to how much money you DON'T spend!..............Frank
Strykass wrote
.....apply some kind of paint or varnish all over the wing...
Minwax Polycrylic, on the other hand, is NOT fuel proof at all. It turns into a sticky mess that is only good for catching bugs...
mjse:
Flew OK. One of the neat things was, if you pulled full back in a turn the speed would bleed off imidiately and it would "skid" through the turn. Looked neat at least. I need to make another but my list of project planes is longer then I'll ever get to.
