Cox vs. Norvel
The Cox throttle is not that much different than the OS LA .10 throttle, which has no airbleed. It works fine. Mr. Cox, your English is pretty good, and even the spelling is.
I don't know about the OS .10LA but the OS .10FSR doesn't have any air-bleed either. This doesn't mean that there is no compensation at the low end though, as there are several other ways to do it. On the OS .10FSR there is a larger bore above the barrel compared to below it, such that the "throttle valve" closes before the "choke valve" and the low end is kept lean. On other engines there is a slot or a hole (plain bearing MP Jet for instance) made in the upper part of the barrel, thereby making a similar type of compensation. On Norvel engines the slot is instead in the part that the barrel will close against. An air-bleed hole (fixed or adjustable) serves just the same purpose, it lets air bypass the "choke valve" and keeps the low end lean.
I think much of this discussion has gotten mired in semantics and/or interpretation. I've no problem with calling the COX throttle a throttle --- in short, it allows me to control engine speed; how that is managed is of no concern. The carbs (throttles) on many of the small displacement engines are nothing more than chokes designed to restrict air intake. This is especially true if the carb has no mixture adjustment screw or air bleed. By restricting airflow, it also reduces fuel flow due to lower air velocity in the venturi. It's similar in the COX throttle --- lower air flow reduces the venturi effect and ultimately the amount of suction at the fuel outlet.
NORVEL's approach was novel in how the throttle barrel is retained. Because it screws into the carb body rather than being retained by a screw, it allows the mixture to be leaned on the idle end as the barrel and attached needle move inward as it rotates.
Red Baron Mike
Yes, I do remember full house; I remember reed radios; heterodyne and super heterodyne receivers; tuning wands and paraffin; tube type transmitters and B cells; and rubber band escapements. What I can't remember is what I had for breakfast.
Red Baron Mike
way to go Bernie ! Started with Cox a long time ago. Found many a cut with good-old "M-Mist", got real dizzy and flew to high many atime prayin it would run out of fuel. Love those engines!!!
#32
Bernie, there is an Ace throttle that was available for $2-3 a long time ago. http://www.coxengineforum.com/t5486-...nturi-throttle . It would work with a muffler I assume. It would be simple to reproduce. It is about half way down the page. There was also a muffler made by Cox? that was a throttle ring that worked fairly well. It had a silicone sleeve over the outside that would burn off after a while. Quite a while I think. Either one of these would give a muffler and throttle. I could take a pic. of mine if you want.
#33
My Feedback: (10)
BC, CANADA
Yes, I know about the ACE throttle. Retail pricing would be in the $20+ range with a production run of 1,000. As for the RC Bee / Dragonfly muffler / throttle, retail price would be in the $30+ range with a production run of 1,000; meaning it may not be a commercially viable project.
Bernie
www.coxinternational.ca
Bernie
#34
Folks:
With apologies for slight thread drift here, I've a question. Does anyone know if NV Engines is still in business? I posted to the Norvel site here and got no response. For what it's worth, I like both Cox and Norvel for different reasons. Am very glad that Cox International makes parts available - would like to see the same for Norvel.
Dave Mo...
Dave Mo...
#36
Bernie (or anyone else who can help):
Thanks for the Norvel link. I've tried registering and ordering but (oddly) I get no acknowledgement through their web site. Even my e-mails aren't answered. Could you kindly provide a phone number?
Thanks very much!
Dave Mo...
Baraboo, WI
Thanks very much!
Dave Mo...
Baraboo, WI
#37
My Feedback: (10)
BC, CANADA
Dave,
Back in 2010, Alex, the fellow who operates the site, gave me his phone # as 562-728-4230. I just phoned there and some fellow (with strong Russian accent) said that Alex was not in and it would be best to email Alex. The email we have on file for Alex is [email protected]
Please also note that we are not affiliated with Norvel; not that we do not wish them all the best of course
Bernie
Bernie
#38
I haven't bought anything from the Norvel site for quite some time (about a year or more), so I don't know how they are doing now.
I believe Alex has the ebay username "honestguy" and he will sell engines through there as well; http://www.ebay.com/sch/honestguy09/...1&_ipg=&_from=
#39
Bernie and Mr. Cox: Much obliged for the responses from each of you. There must be some kind of activity yet, so I'll give them a try and let you know how it turns out. Thanks!
Dave Mo...
Dave Mo...
#40
#42
My Feedback: (18)
I like both Cox and Norvel engines but each is best suited to their own type of aircraft. Smaller lighter airframes get the Surestart and larger airframes the Norvel. That said, I usually prefer my Cox powered planes because parts are readily available, so no worries about mishaps. The Norvels engines are great but if the ground rises up to smite my plane then it's a problem finding the parts if I need to fix the engine.
