Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
2015 Design Contest - The Roger Dodger
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 05-08-2015, 09:40 PM
BMatthews
BMatthews's Avatar
Default 2015 Design Contest - The Roger Dodger
OK, time to put up or shut up. Here's the concept sketch I did a few years back then parked it on my hard drive. I think this could be a really fun sort of plane at around 40 inch span for a Cox reedie or a Norvel .061. It's big enough to soak up the power without producing a LOT of speed and should be good for a few rudder-elevator stunting. The goal is to produce a fun model with some zip yet one which can slow down and really hang up there on almost no power.
Here's the concept sketch I did way back then in 2011. The plans got a start but I only laid out some fuselage former locations and then some shiney object lured me away.
You can see that the original concept was for a rather small electic model. I may still make one for big hall indoor flying but for now I want something for outdoors which can kick back against at least a moderate amount of wind. So I'm going to play around with 38 to 40 inch span. The wide chord should ensure a low wing loading. That and the idea is that it'll be done in a very light sort of structure with one of the light parkflyer films for covering. Or I may go with esaki tissue and dope. We'll see.
Name:	Rodger Dodger 3v.gif
Old 05-08-2015, 11:05 PM
Pond Skipper
Pond Skipper's Avatar
Looks good Bruce, should be a real sweety in the air, nostalgic ticking along looking proud coming from any direction.
Old 05-11-2015, 07:51 AM
BMatthews
BMatthews's Avatar
CAD drawing is coming along. Span has been decided on at 38 inches which gives 290 square inches of wing area. And with mostly air surrounded by a little balsa and film or tissue this looks to be a model that can be pretty easily built down to around 16 oz. So it should be able to catch a thermal here and there. But the size and polyhedral should also allow it to do some pretty funky rudder/elevator aerobatics. I've also slightly deepened and fattened up the fuselage to give it a little more of the pudgy cartoon look. The little sketch version above looks good but it's a bit too much like a "proper" Dodger carrying an umbrella for the wing. Fattening it up a little makes it look really good like the chubby kid that everyone likes....
The plans are a rough hodge podge at the moment so no point in trying to post anything. It's always a messy part when doing the extensions for drawing fuselage formers. So nothing to show for now.
