dragonfly tank?
dragonfly tank?
I got one off e-bay, and found one at the swap meet...dont quite get the orientation ?
does the cylinder fly/mount on the side? or does the needle valve/filler tube go on the side? if thats the case than it looks as though you could only fill the tank 1/2 way..
one is the white tank (no clunk) with crappy hollow muffler, the other is a black tank(with clunk) with the nicer muffler/throttle ring,both are alittle gunky...thanks.. Rog
RE: dragonfly tank?
Thanks Tim, a couple more things the black one has a metal reed and the white has a clear plastic one, the white one does have a clunk line but it has turned to a hard plastic line with no weight on it,, the black one has a cone shaped weight on a still pliable line.. did they use these on some kind of production plane or something? The white one was obviously built cheaper, the first white tank one I've ever seen......thanks, .. Rog
