.010 Bipe - It flies!
RE: .010 Bipe
I had originally considered a Jedelsky wing, but I think I'll cut a Clark Y out of foam. I think it would look best with a built up wing, but foam is the easiest for me.
AJC
I'll send you the plans if it flies.
AJC
TN
RE: .010 Bipe
ORIGINAL: Bipe Flyer
RE: .010 Bipe
After investing in the CNC foam cutter I have to justify it somehow.
It doesn't show on the drawing above, but it will be R/E with dihedral.
RE: .010 Bipe
I was going to just make unsheeted extruded blue foam wings, but I decided that fully sheeted expanded white foam would be nicer. I used 3M77 to attach the 1/32 light balsa sheeting. I used this same method with the same thickness of sheeting and density of foam on my .46 sized Pitts. Overkill you say? Yes of course, but here's the kicker; I weighed a LS wing that I had framed up but not covered and it only weighs 2 grams less than all four sheeted wing panels combined!
RE: .010 Bipe
HI BIPE! That cross section shows how skimpy light the 1/32" looks, even on such a tiny wing. The trouble I have with 1/32" selection at the LHS, is it is stringy, tough and heavy as light 1/16"! I'm sure there is a good mail order source of the stuff, but that tends to be a crap shoot being at the mercy of someone elses' judgement. I either buy from LONESTAR, BALSA USA, or SIG. Even on a 15" plane, that .010 looks TINY! I've never seen one run, imagine how much more critical the tolerances are than with a bigger engine.
RE: .010 Bipe
The wing, as usual, looks real good. Is the 3M77 you used the most recent formulation. For some reason, old age being likely, I thought someone had said the formula had changed and was no longer foam friendly. Obviously not since you were able to use it.
the "other" Andrew
RE: .010 Bipe
CP
I got some 1/32 sheet where the QC wasn't very good and the thickness varied from sheet to sheet. This made it a real pain for joining sheets, but I just picked two of the thinner sheets for this wing.
Andrew
I read about that in rec.models.rc.air back in March of 2002 but I've yet to see any of foam dissolving 3M77. Apparently the foam safe is in a black can and the type that attacks foam is in a red can.
Strykaas
I just haven't gotten around to finishing up the plans.
Andrew
Strykaas
RE: .010 Bipe
I got the fuselage framed up today, but the fin looks a little small. I may make another one.
It's under 2 oz, including engine, at this point.
RE: .010 Bipe
Andrew, that little thing is beauteefulllll. An absolute cutie. I am thinking you will have a real floater with all that wing area.
Initially, I was inclined to agree with you about the size of the fin, but after seeing how well all the little Willard planes fly with their small fins, I am not sure you don't already have it right. With all that being said, I personally tend to make my stabilizer surfaces a bit larger (2-3% or more) than normal on my smallest planes.....
Keep posting. Can't wait to see the finished product......
Frankly if you were to re-shape the fin a bit, you could almost get away with calling it the 'Light-BeerCat' [sm=lol.gif]
RE: .010 Bipe
Thanks Match. I'd rather err on the side of slightly larger stabilizer. I'd rather have a plane want to tuck a little in the turns than not know which end points to the front.
Now that I think of it, it does look a bit like a Beercat. That wasn't the intention but I guess that working on the 1/2A Beercat plans has rubbed off. It just goes to show that no matter how original you think your design is, you are always drawing on past experience to a certain extent.
RE: .010 Bipe
I got halfway through a rebuild and then suddenly thought that without a decent powerplant I was wasting my time.
The enya .09 couldn't pull the skin off custard, so I'll sell that and get myself a nice .074 I think.
Then I'll give it another go
My Feedback: (20)
RE: .010 Bipe
ORIGINAL: Rendegade
The enya .09 couldn't pull the skin off custard.......
BF, neat neat plane you've got there. Do you ever sleep?
phil in austin
